G
Gary Palmer
Hi,
Im after some advice, I recently refurb'd my Kitchen. When the kitchen was re-wired I put in place one circuit with 3 connection points to install a light under each cupboard. This is fine if I wanted standard tubes underneath, however I'd like to fit some LED strip lights, however I now find that most of these are connected via a seperate 'link cable'. I cant use these as my wiring is buried underneath the plaster.
So the only solution I can think of is to wire in a transformer/driver at each connection point (cupboard) in the circuit.
Is there any reason not to do this? or a better way?
Cheers
Gary
Cheers
Gary
