T
TonyH1208
Hi Everyone,
My name is Tony and I've just registered.
I've spent 30 years in the computing industry installing large mainframes etc. I know my way around electrical circuits and theory but have no formal qualifications.
I have a question.
I'm having a new kitchen fitted shortly and having installed a single oven rated at 3.6Kw and a microwave rated at 3.6Kw also. My existing kitchen has a double oven which is fed by a 30A cartridge fuse via 4mm cable to the cooker isolation switch in the kitchen. The total distance is around 10-12 metres.
Looking at the power rating for this circuit, I think it should run at 7.2Kw which is the total of my two new appliances. However, I'm a little loath to run any circuit to its maximum capacity in case the circuit trips or, worse, becomes a fire risk.
I'm looking at running a 6mm cable from my existing consumer unit to an additional 2 to 5 way consumer unit directly above the kitchen in the eaves. The original Wylex CU would have the fuse rating upgraded to a 40A MCB and the new consumer unit would have two separate circuits each rated at 30A to each individual appliance.
Is this the best way to do it, or would the existing circuit be sufficient anyway?
Although I will be doing the work myself, I intend to get a professional electrician in to certify the installation afterwards.
Many thanks,
Tony
I have a question.
Many thanks,
Tony
