hi, a customer has asked me to put in some extra sockets which are going to be run surface trunking extending from an exsiting socket radial. The supply is TT. The supply tails go out of the meter into a 30ma rcd 100amp enclosure unit out and into henlys then spit into two small old 5 way wylex rewireable fuse boards. can i carry out work ? bonding is in place . customer doesnt want a board change.
thanks
thanks
Yes, dont see why not. Do your tests properly though and make sure all is within spec. Your main incommer is RCD protected so as far as i can see it is 17th compliant. Just because its old doesnt mean its dangerous.
Cheers........Howard
thanks for your help i done a loop test , rcd all fine. and a ramp test came out at 24 so should be ok.
Swansea, South Wales
advice please
Australia
mattyevz,
mattyevz,
