C
cols42
Hi all, I registered here as I've got a few questions and need some advice.
My situation is that I'm 35 years old, and after deciding on a career change (I used to work in finance) I took a course and I am now qualified to level three of the C&G 2330 Electrical Installations to the 17th Edition (finished my course last July). My original plan was to get working in a firm and from there get my 2391 and NVQ done, then get my full scope part P and eventually go self employed.
However, I'm finding it very difficult to get work, probably due to lack of experience.
I was thinking of just going for it and going self employed asap, however I need to be able to do this legally! My understanding is that part P is required in order to be able to sign your own work off, and to get part P you need the 2391 as well as the 2330. Is this correct?
Getting the part P for me seems a bit chicken and egg, as to get the part P I would need to be working somewhere (so they can come out and check my work).
So I was thinking I could go into business with my Dad - if the two of us went self employed, if my Dad got the 2391 test and inspection qualification, would this mean that he could test & inspect and sign my work off? Also, as my Dad isn't qualified, if I got the 2391 and he did work under my supervision, would I be able to test / inspect and sign that work off?
If possible, that would be the quickest route for me to get working in my chosen career - I could then get my full scope part P done whilst working with my Dad.
I'm a bit confused about what is required in order to go self employed - obviously the main thing is to be able to test and inspect the work that it complies with regulations and to sign that off - my understanding is that part P is required for that if signing your own work off (but I'm not sure what exactly is required for that), but also that 2391 is required to sign someone else's work off - if that's correct my plan of working with my Dad seems ok but I just need to check that it's ok before going forward and researching business grants and doing a business plan etc...
Thanks in advance for any advice!
Cols
Cols
