A
avoman
Hi i have a belling hob that is rated at 6.3kw and getting a bosch single oven .Oven manual states it should be on 16a it is 2.35kw it says not to use a 13a plug.
My cu has it's own cooker circuit which has a 40a fuse fitted .Theres a CCU on the wall within 2m of where both will be .And theres an outlet plate (dual outlet plate 45a click plate) behind where the oven would go.The hob is fitted to the outlet plate using 6mm2 t&e can i just connect the oven using 6mm2 t&e from the outlet plate to the oven an class them both as one cooker ?
