Discuss Advice sought on spurs off spurs in the DIY Electrical Advice area at ElectriciansForums.net
that's the lazy way out.basically you have the landing light with the N from the upstairs circuit, and the L from downstairs. was common practice 50 years or so ago, saved running a 3 core for strappers between switches. such an arrangement is potentially dangerous unless both lighting circuits are on the same MCB. (which contravenes the "division of circuits reg.".).The circuits were split differently but after spark had gone home when I turned on the landing loght both rcd’s tripped. I called & he came back the next day & explained there must be a shared neutral between the lighting circuits & had to rewire the panel which meant the loads would not be split how he originally intended. That fixed the tripping issue. Does this seem a plausible explanation?
What is an rcbo board & why?
Reply to Advice sought on spurs off spurs in the DIY Electrical Advice area at ElectriciansForums.net
