Advice - vary speed of 240v 18w 80mm fan | on ElectriciansForums
Discuss Advice - vary speed of 240v 18w 80mm fan in the UK Electrical Forum area at ElectriciansForums.net
T
TonyChapple
Morning everyone!
I would really appreciate some advice please.
I've bought a small 240v 18w fan to help circulate air in plastic box used for drying food (biltong!)
Could someone advise me on the best way to vary the speed of the fan?
all the fan controllers I've seen dont seem to work on fans as low as 18w
So..... Anyone have any suggestions?
much appreciated
Tony
Thanks telecritx - sensible suggestion.....
i had read on tinternet that fans and dimmer switches don't always work ... But as you say - cheap experiment!!
Any other adivce from others?
Cheers
tony
You can get exactly the same face plate fan speed control, as a straight dimmer. Most domestic fans are only 40W motors, so they should be able to control an 18W fan.... other than that, as you say, try Tel's suggestion...
Where you located Tony? Biltong isn't a thing they'd know much about in the UK :)
Can you attach a picture of the fan motor?
Fan speed controllers are usually rated by the maximum motor size they can handle, they can often be used on motors much smaller than the value they're rated at.
If you're going to try using a lighting dimmer for speed control I would use a dimmer with at least 5 x the capacity to accommodate the higher starting current and the fact a motor is an AC3 (highly inductive) load.
Whatever you do to reduce the speed I would only go as low as half the original speed. If you go too low the motor will overheat especially if it TEAO
If you can post a picture or two or give us a link to an datasheet for the fan on a website you'll get better advice.
The only difference between some fan speed controllers and some dimmers is that the speed controller is configured to reduce the speed by a maximum of about 50% whereas a lighting dimmer will go down to almost zero. A dimmer can damage the motor if it's set too low for the cooling to be effective.
Sorry for not replying sooner!
My biltong project is still ongoing....
The fan is 70mm diameter, about 40 mm deep from RS
it has a stock no. 509-030 (can't find on Internet) the sticker on the fan says
240v a.c. Fan
50/60 Hz 18 watt
Impedance protected
Case must be earthed
Made in west Germany
Could really do with some help !!!
Cheers tony.
Reply to Advice - vary speed of 240v 18w 80mm fan in the UK Electrical Forum area at ElectriciansForums.net
