R
Robo
I plan on installing 4 new tv point in a house. I intend on running 4 seprate coax to each point and then connecting to a 4 way splitter. from the splitter to a booster and from the booster to the aerial. Does this sound the best way of doing this?? Robo
If freeview/DAB yes. Just make sure signal is'nt to strong as it wrecks tv's long term.
If sat, use a tri-ax system with magic eyes. A feed to the sat box and r2 back out to the tri-ax booster.Then out to rooms.
Its just a normal tv aerial system. How do i determain if the signal is to strong?? Do you know any websites that give a wiring diagram for the sat system u talk of? cheers b spark
Aerial and co ax install.
Australia
Robo,
davelerave,
