After the PIR | on ElectriciansForums
Discuss After the PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
oldtimer
After you issue a PIR and you class it as unsatisfactory and you are asked to make good the defects what paperwork should you issue ?
Depending on the extent of the remedial works either MW or EIC, detailing exactly the works carried out and linking back to the PIR number and defect reference.
Together with these certs I usally attach a letter confirming that all remedial works to PIR number........have been carried out.
Reply to After the PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
One that uses an internal relay to do the switching most are. https://www.screwfix.com/p/zinc-dion-outdoor-black-pir-sensor-180-/388ft?ref=SFAppShare
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
