Ahsp via sub main | on ElectriciansForums
Discuss Ahsp via sub main in the UK Electrical Forum area at ElectriciansForums.net
England
New build project still on the go. Property having detached double garage with an all electric studio flat above. The garage will be wired via u/g SWA sub-main.
The AHSP for the house will be sited by the detached garage. At this point in time I'm proposing to wire the ASHP from the garage on it's own circuit.
The box of tricks (Apollo?) for controlling the heating etc will be sited within the house. My question is..Apart from the main circuit to the ASHP, do i need to wire any other cables between the ASHP and the box of tricks in order to control it? I take it normally the ASHP would be sited by the house with it's own dedicated circuit and as standard the detached garage via a sub-main. Does having both on the sub main make sense both electrically and viable?
I am in the process of getting more info via the owner from the manufacture but thought I'd like to ask here from experienced guys who install these on a regular basis.
thanks
Reply to Ahsp via sub main in the UK Electrical Forum area at ElectriciansForums.net
So this was resolved. I used a line tester to see if I had power across the breaker on the main box in the house. Breaker tested fine. Then I...
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
