AHU Faults | on ElectriciansForums
Discuss AHU Faults in the UK Electrical Forum area at ElectriciansForums.net
spatz
I'm having a problem on an AHU that will not hit btemperature the actuators to htg coil are fully open and hot water is passing through but i am not getting my set point met by 8 degrees C, can anyone give me some advice please
More info needed.
Is it Full fresh air, fresh air+recirc or recirc only?
Are the filters clean?
Is the coil clean?
Is there a difference in flow and return temps on the pipes?
Has it ever worked correctly?
Has it ever worked correctly given the current outside temps?
Has anything changed in the area it supplies since it last worked correctly?
Is the boiler flow temp at it's setpoint?
Is it a dedicated boiler to that unit?
Reply to AHU Faults in the UK Electrical Forum area at ElectriciansForums.net
I
Cleaning a Magnetic Filter without an isolation valve Hello All, We have a Vaillant boiler, it has an advanced protection kit fitted that gives...
i3_happy
I
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
