aico interconnects quickie | on ElectriciansForums
Discuss aico interconnects quickie in the UK Electrical Forum area at ElectriciansForums.net
SPARTYKUS
Hello
Quick one as not somewhere I can look up easily- standard mains ionisation (161i?) -do they or rather should they BOTH go off when one test button is pressed?
Only have generally worked with Aico's for a long time, but even the other brands all interlinked detectors should sound. With Aico's no matter what you have be it a Smokie, heat or carbon, if interlinked they should all sound. Likely to be a very short delay from the first detector sounding to the others sounding.
Danke schone mein fuhrers. Great aico site. Ta needasparks. Yes it should operate all interconnected alarms. Damn it thats annoying. Its at a family property, not home, was flooded, i know the spark that fitted new smokes. Annoying.
Reply to aico interconnects quickie in the UK Electrical Forum area at ElectriciansForums.net
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
I had a teacher at school whose surname was Dallas...and he had a very large nose... We called him The Yellow Nose Of Texas...children can be so...
