aico mains wired interlinked/radio linked smokes and heat detectors | on ElectriciansForums
Discuss aico mains wired interlinked/radio linked smokes and heat detectors in the UK Electrical Forum area at ElectriciansForums.net
J
juanpabs
A little query for you guys that fit these smoke detectors, I've got a site visit next week to quote up for a landlord requesting more smoke and heat detectors fitted in his apartments. He has explained on the phone that he currently has aico mains wired smoke detectors fitted in some of his properties already, now I believe these are hard wired linterlinked. My question is, can I simply by adding a radio link base to one of the hard wired interlinked smokies then a radio link base to any new detectors ensure they would all be linked? Seems like it should work fine in my head but having never used the radio link bases before and cannot find anything confirming if this is possible.
Cheers
Yes, replace one existing base for radio base......then expand using wireless.
only code one apartment at a time, otherwise all apartment will be on the same code and sound together.
Just out of interest....Had to use 12 radio linked 10 year battery aicos on a Georgian property a few years back. This was due to decor and lighting cables being run in old gas pipes...After specs going back a forward, the insurance company agreed, and allowed the system to be downgraded F from proposed D.
Gosh, a bit of common sense applied through sensible communication!
Comes to a point Clive, were you can`t do the impossible..... Building and interior were listed, so we could not damaged plaster light decors, which were very fancy. Insurance company commented that grade F would be better than no detection on a £4.2 million property.
Precisely, but muppets think they can cut corners in relatively modern properties rather than doing the job properly.
Just imagine if somebody downgrades the alarm without discussion with the insurers - the LABC aren't likely to spot a battery unit, yet come an insurance claim following a fire, your £2M PL, would come up well short!
Reply to aico mains wired interlinked/radio linked smokes and heat detectors in the UK Electrical Forum area at ElectriciansForums.net
