Aico Smokes. | on ElectriciansForums
Discuss Aico Smokes. in the Australia area at ElectriciansForums.net
I
ian
I recently rewired a house and fitted a smoke detector to in large lounge which tested ok at the time of installation, however since then the client has had a flueless gas fire fitted, after the fire has been on for around 5 minutes the smoke goes off which then sets off the other 5. I have subsequently tried replacing it twice with both optical & ionising detectors. The smoke if fitted around 7 meters from the fire.
Any suggestions why the smoke should go off.
Cheers guys.
Ian
If you have tried replacing the detectors twice, ...and with the 2 different varieties of smoke detectors, then it seems as if this new gas fire is emitting combustion particles into the room and the detectors are sensing them. I would get your client to contact the gas fires manufacturer, as this shouldnt be happening...
Reply to Aico Smokes. in the Australia area at ElectriciansForums.net
Yes, that was actually something making me uncomfortable too, the bonding of it all. I need to have another look at it, I'm not sure if the...
