Usually install Aico smokes/heats but just noticed quite a large price difference with FireAngel.
Any with experience of the latter - fitting, reliability etc?
Discuss Aico vs FireAngel (and others) in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I used to fit a metal box or fast fix box when we fitted the square ones with fly leads (Aico) when we started using the round ones carried on as I always found the room tight.there's not much space in the Aico ones to make the connections when interlinking but ones you've connected it up it looks a lot smarter and the unit fixes to the base much easier than others.
There's no space in the fire angel things, the connector sticks out from the back of the unit, horrid. Twice recently I've had to fit that rubbish, took ages messing about fitting plasterboard boxes in the ceiling to contain the wiring. I don't ever want to fit any more again.there's not much space in the Aico ones
Reply to Aico vs FireAngel (and others) in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
