air 2 air 2 water heat pump | on ElectriciansForums
Discuss air 2 air 2 water heat pump in the Green Lounge (Access Only) area at ElectriciansForums.net
Thanks but...................................it's not what I'm looking for :) I need a combi system ie: one that can supply hot water and air from the same outdoor unit. A potetial client claims to have been told of one but i cant' find any information on them.
Air to air have been around for ages (air conditioning in reverse) Air to Water equally, If he wants an air to water to air, it's simple enough - its just a big fan assisted radiator, so usual air to water and an industrial forced air heater ...
Myson Hi-Line Fan Convector Heater. New Myson Hi Line Fan Convectors
Myson Hi-Line Fan Convector Heaters : Myson Hi-Line RC 10-6 Fan Convector Heater
"he units are easy to install, control and maintain, therefore providing a simple yet effective method of heating. All models have a fan only option for cool air circulation. Engineered predominately with the domestic market in mind, the re-modelled and very discreet HI-LINE RC unit is the only remote control version of this kind that is curretly available for hot water products. Output(BTU/h) Boost 10,500, Normal 6600"
Jaga - New Heat Emitter Guide Singles Out Jaga Fan-Assisted Radiators As Ideal For Use With Heat Pumps
Worcester I was about to say it's not what I'm looking for but...............................................................hold on..............I could make it work with the Myson hi line units :) Thanks for that.
Reply to air 2 air 2 water heat pump in the Green Lounge (Access Only) area at ElectriciansForums.net
N
Air Source Heat Pumps I have been thinking of going on this course but my only reservation with it is reaching out to the right clientele, has...
Nwalky
N
M
Heat pump hot water cylinder Has anyone fit one of these? A hot water cylinder with a mini heat pump on top with ducts for air in and out. Heat...
Matt0029
M
