Air bleed magnetic filter Can someone please advise how to bleed air from a magnetic filter installed on a Worcester Greenstar boiler. I don’t want to clean it out as that was done by a professional engineer who seemingly left me with this problem. Specifically, should I close the valves either side of the filter before opening the top bleed valve? Should the boiler be turned off? Etc, etc
Comments appreciated.
Air bleed magnetic filter to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
