B
Ben Butcher
Hi Everyone,
I apologise, this is going to be a bit long winded! Any help would be gratefully received though.
I have just finished wiring the supplies for an air source heat pump. By manufacturers spec it needs a 32A supply outside for pump itself, and a 16A supply to the indoor control unit, so that is what I have given it. The existing installation is TT with a 10 way Hager CU and a separate 30mA 100A RCD/Main switch, the CU itself is old school with straight isolator (100A)
Basically the problem is that after installing the two circuits, and prior to connecting them I couldn't get a very good earth reading at the CU. I scratched my head for a bit, and then found that the connection to the earth rod had broken off, the earth rod by the way is only about 2 months old as they had had problems with nuisance tripping.....I dutifully reconnected the earth and continued (got a Ze reading of 232 ohms, a little high I know but given there was nothing before I was keen to carry on a worry about that at the end.)
Anyway, finished wiring everything and switched it all on, after about 5 mins the whole installation switches off at the RCD, and continues to do this randomly untill I switched off the PV to save it from damage. At this point the rest stayed on fine. At the moment the RCD seems happy with either the whole house and PV, or the whole house and Air source, but not both????
Is it possible to overload an RCD and will this make it trip? I am tempted to fit another separate two way CU for the Air source but of course there is very little room in there and the customer is beginning to look at me like a fool on the basis that "it was all OK before...."
Any tips would be very gratefully listened to. Thanks in advance, Ben.
