uksparks
Hi,
I have owned all these from new and looked after them as best you can whilst using them, they have all had very little use. I was going to use them to do a car up, but it never happened, so they have just been used for the odd little job. The ratchets have been used perhaps 3 times, the die grinder never I think, the cut off tool, twice maybe. The tools, although they look quite used, they are not, the problem is, over time they easily scratch, or when using them, if they are placed on a rough surface like a road or driveway then they get scratched, but all in good working order. The tools that required oil were always used in conjunction with an inline oiler too.
See a list of all the items below including the price of how much they are to buy new now which comes to over ÂŁ700
- ÂŁ74.70 - SIP 06772 1/2" Extra Heavy Duty Low Noise Ratchet
- ÂŁ74.70 - SIP 06770 3/8" Extra Heavy Duty Low Noise Ratchet
- ÂŁ72.23 - SIP 06766 1/4" Extra Heavy Duty Low Noise Ratchet
- ÂŁ55.62 - SIP 06764 1/4" Heavy Duty Die Grinder
- ÂŁ62.24 - SIP 06762 3" Heavy Duty Cut Off Tool
- ÂŁ181.46 - SIP 06776 1/2" Air Impact Wrench
- ÂŁ58.12 - SIP 7521 3/8" Reversible Air Drill-Keyless Chuck
- ÂŁ56.99 - Sealey SA39 Tyre Inflator Long Type with Twin Push-On Connector
- ÂŁ52.00 - SIP 07195 6" Dual Action Sander
- ÂŁ82.00 - FIAC Kite Mini Spray Gun
- Unknown brand spray gun.
A couple of air dusters and a shot blaster handle which I have the pipe for, you just put the pipe in the sand or grit etc. The smaller spray gun is really good, I used to be able to get a really good finish with this on the small jobs I did on my car.
This set of air tools would really help someone set up garage / home repair business or similar
