airing cupboard temp | on ElectriciansForums
Discuss airing cupboard temp in the UK Electrical Forum area at ElectriciansForums.net
A
ample current
Hello all,
What would you concider to be the ambient tempurature inside an airing cupboard be if you were to run a cable through it so it can be derated accordingly.
mine is that hot and it;s a manufacturers lagged tank, the one with the foam jacket. small cupboard, door closed, soon get a heat build up.
Reply to airing cupboard temp in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
I guess my last post was even less direct than intended.
nicebutdim
N
