alarm cicuits | on ElectriciansForums
Discuss alarm cicuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
ashdog
Hi
When supplying an alarm circuit on a 17th edition board should it be RCBO protected on non RCD side,on RCD side or on MCB on non RCD side?
I thought RCBO on its own but chap i'm working with disagrees
I would prefer to install RCBO / NonRCD. This provide RCD protection, but cannot be effected by any other circuit, same as smoke alarms.
Would agree, totally seperate.
You can still fit the RCBO circuit after the main switch and before the first RCD unit i.e:
Main switch > RCBO > RCD > Circuits > RCD > Ciricuits
Or opposite:
Circuits < RCD < Circuits < RCD < RCBO < Main Switch
Warren
Reply to alarm cicuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
You cant just "avoid" the use of RCD's for nuisance tripping... it will depend on how the cable is routed. (ie buried less than 50mm) What has...
