P
pici
Hi there,
I have a honeywell optima compact panel and wanted to do the walk test, but doesn't work. Tested detectors given them direct 12 voltage, they are ok. They don't get 12 voltage from the panel, checked wireing, it is wired as shown, it should be correct. Checked output on panel and it is 1.2 voltage instead of 12 voltage at points ( +13V, -0V), where I connected the detector's (+,-).
What did I do wrong?
many thanks for all advise and a happy christmas to everyone
