alarm going off in middle of night? | on ElectriciansForums
Discuss alarm going off in middle of night? in the Talk Electrician area at ElectriciansForums.net
sparkyb
A woman phoned me the other day saying that her alarm went off in the middle of the night when it was not even set. Any ideas?
If its a wireless one, I've had one that beeps when there is a possibility of RF interference.
OR if the battery is knackered in the panel and there is a slight powercut, that can set them off too
Get the instalation manual as most alarms have a log that tells you
the last 10 alarms and the zone that caused the alarm.If you havn"t
got the manual you can download it.It could be the tamper circuit
Check that all the covers on the pir"s and the keypads and main box are not
loose.
I would hazard a guess it’s the tamper circuit. The last one of these I had was on the outside bell box.
[FONT=&quot]Ian [/FONT]
tamper fault,could be the bell or a corroded contact,loose lid on a pir,cable fault needs the meter out and take some readings at the panel
Reply to alarm going off in middle of night? in the Talk Electrician area at ElectriciansForums.net
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
