alarm parts interchangable | on ElectriciansForums
Discuss alarm parts interchangable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
South West
Can someone advise me if wired alarm parts are normally interchangeable with other makes?
Customer has a accenta G6 panel but wants new keypad and PIR's as existing ones are looking a bit tatty. Never actually replaced alarm parts, only fitted complete systems so unsure if you can use different make parts then accenta.
thanks
For Grade 1, (domestic usually) PIRs, generally, can be interchangeable, as can door sensors. It can get complicated with Grade 2 alarms, as they may need resistors adding to the sensors.
Keypads are generally not interchangeable between makes.
For the Accenta, there are 2 types, LED or LCD.
Being as it is Honeywell, I'd go for their sensors too, easy to wire, and pet tolerant.
Reply to alarm parts interchangable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
