Alarm problem
solar_first
I hope some auto tech can advice me. I have dodge journey 2009. When I close the car with remote, Its alarm start making noise by itself.
If you have had the bonnet open recently check the bonnet switch quite common on most cars for this to start happening after you have checked the levels or topped up the fluids
Many Thanks
- - - Updated - - -
What if its goes off after few hours and some times its doesnt.
plug it in to a diagnostic computer and it will tell you what triggered the alarm at any time. just do a global scan for all faults, erase them all and then go from there.if some don't erase, then you know you have an issue with whatever it says.
hope some or all of this helps.
