Alarm sounds when deactivated | on ElectriciansForums
Discuss Alarm sounds when deactivated in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Dorset
Don't normally deal with alarms but a customer has asked me for advice and consequently I come here!
Old system (circ 1980s) occasionally alarm goes off during the day when its been de-activated, type in their code and it stops and everything OK until the next time. Happening more regularly.
New battery required?
Hi,
Mine sounds when landing light is turned on and then stops when it is turned off. All other room lights do not affect the alarm. Baffled why I get this affect with only one of the upstaris lights as it appears to rule out any voltage drop that might be sensed by the alarm unit. System is an old wired installation.
Grateful for any ideas please.
Hi,
arcing in the light switch or fitting could cause this. check all connections relative to the landing light and if necessary, replace the switches ( i assume it's 2 way ).
Reply to Alarm sounds when deactivated in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
