Alarm spur | on ElectriciansForums
Discuss Alarm spur in the Talk Electrician area at ElectriciansForums.net
A
alwaysared
Hi All,
Can someone tell me the rules regarding the fitting of an alarm fused spur, does it have to be installed by a qualified electrician or can the alarm installer do it?
Cheers,
Del
If its an addition to an existing circuit and not in a special location it can be undertaken by any 'competent' person. You don't have to be part P registered or hold any specific qualification.
Thanks for the reply, that's what I thought but it's good to hear what the pros say. I've been out of the country for the last ten years and I used to do electrics but I'm not qualified to issue certificates etc.
Del
Reply to Alarm spur in the Talk Electrician area at ElectriciansForums.net
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
