ALFASOL 3 Solar Heating Controller | on ElectriciansForums
Discuss ALFASOL 3 Solar Heating Controller in the Solar Thermal Advice Forum area at ElectriciansForums.net
London
I came across this controller that is used to heat a tank located in the loft of a house.
The controller seems to be faulty as all 3 temperature sensors are reading -20 deg C.
I cannot find any documentation on this controller and wondered if anyone has come across it.
Do you know where I can get a manual? Search on the internet returns nothing surprisingly.
I have changed one of the temperature sensors but the controller still reads -20 deg C.
Attached is a photo of the unit. Not the best I have taken.
Thanks in advance
Ev
  • [ElectriciansForums.net] ALFASOL 3 Solar Heating Controller
could you have wired the temp sensor the wrong way round?
i would start by attaching the sensor straight to the unit, avoiding any of the existing wiring.
if it still shows -20 then swap the 2 wires round, if it is a thermocouple it will make a difference, if it is a resistive sensor it wont.
Reply to ALFASOL 3 Solar Heating Controller in the Solar Thermal Advice Forum area at ElectriciansForums.net
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
