All metal Consumer unit | on ElectriciansForums
Discuss All metal Consumer unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Lincolnshire
Hi. I used a Lewden all metal board the other day with RCBO`s and have to say I was very impressed. The board is a little taller than standard and the RCBO are quite small, tighten up with real positivity and assurance. All adds up to plenty of room to work with. Yes they are a little more expensive but much easier to work on and neater than cluttered twin RCD boards. I have started to go away from the old boards and prefer all RCBO.
[ElectriciansForums.net] All metal Consumer unit
  • [ElectriciansForums.net] All metal Consumer unit
I use the Wilts version of these - great value for all RCBO boards.
My main issue with them is no 20 or 25mm round knock outs .....
a Denmans special. I here that, no round knock outs on the top or bottom also the Curve variety front cover has an issue with it overlapping causing problems with trunkning..a design fault no less.
Reply to All metal Consumer unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yep, that’s what I do. That spare RCD has always come in handy down the line.
I wonder if a double row Fusebox would fit in there…
