All these circuits with spot lights & transformers! | on ElectriciansForums
Discuss All these circuits with spot lights & transformers! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Goody
London
Hi,
While doing an IR testing on the lighting circuits, these spot lights & transformers are a pain in the back side. The transformers are usually in the most inaccessible places and if you test them with 500v they get blown up or give undesirable results.
Is testing IR only between earth and live & neutral put together is acceptable in such situations?
Cheers!
As its a described method in GN3 then its acceptable.
If you can't disconnect them theres nothing else you can do, other than leaving the switch to them open, then you don't even test lives to earth then.
GN3 is worth its weight in gold mate.
It depends whether it's an initial verification or not.
If it is, then you should test before connecting any sensitive equipment.
If it isn't, then yes it would be acceptable to have such a limitation.
He doesn't know what it is
Here we go again!
Hi fuzzydunlop, every useless post is a waste of space on the server. Please stick around, read the posts at least twice, try to understand, ask questions if you are not sure and learn. Probably, one day you will have enough knowledge & confidence to help others on this forum.
Merry Christmas to you!
Reply to All these circuits with spot lights & transformers! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
