All three RCD's tripped | on ElectriciansForums
Discuss All three RCD's tripped in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Dutchbyname
Good evening every body.
Im new here so hello to one and all
I have a question. I plugged my new 1710 Megger into a TSO in a garage with a two way board on a 30ma RCD. I did an RCD check and my X1 took the RCD out in the garage and the board in the workshop and the main house one too..
I couldn't afford a new trip MFT bug I'm not sure why all three RCD tripped. Time on the test was 37ms so maybe a bit high but doesn't explain the other two. I done no more testing on the installation yet btw
can anybody advise
thsnk you.
Dutch
can anybody advise
thsnk you.
Dutch
Sounds like the installation is badly designed with 3 RCD's in series which does not provide any discrimination between the devices. 37mS for a X1 test is by no means high.
wow that's a great post Sintra. Thank you very much. It's over RCDed then! Could therefore the garage RCD just have a main switch in it?
Hi. There is a 6mm from house to workshop (workshop attached to the side of the house) which supplies the board. This has simple lighting and a few socket outlets)
from there that board via an amoured cable runs up the garden to a garage where you have a couple of lights and two sockets. Garden is about 15m long
Once you have confirmed the wiring arrangement is as described above then it would be possible to replace the garage RCD with a main switch, however this will mean that any fault will trip the workshop or house breakers which will take a out a lot more than just the garage and require you to go back to those locations to reset.
Ideally you would have independent RCD protection local to the garage to minimise the tripping of non faulty supplies and make it easier to reset.
Reply to All three RCD's tripped in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok I’ll try this when I’m down
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
