Good price plus you get the 30 day money back guarantee.
I've used iss before they're part of eddies so trustworthy.
Unfortunately I've never used nor no one else that's used aphatek stuff so can't be more helpful sorry.
Jim
Ours went back because of a fault, took 8 weeks to be returned, however, they did give us a loan unit. Came back, within a couple of times of using it, started to play up again, so it went back, again. 8 Weeks later, still no tester, Technical department refused to talk to me?? not sure why, and the rep ended up sending me a new one. This one's been ok, still get a few strange readings from time to time, one thing to note, we leave ours in the van overnight, and when there is a frost, it will not work until it has warmed up a bit, you just get a little thermometer symbol on the screen!!! 5 mins in the sunshine and its good to go!
i have one works well i use it every day . i did have to send it back to get the software in it up dated but got it back in 3 days :)
Had the same thing with my Megger except Megger wouldn't replace it, they even claimed it might be a fake at one point. Got it from a big national wholesaler, who did replace it for the Kewtech KT64 after 18months of messing about.
On the flip side of that I've had a Megger Cont & IR tester that's been rock solid for 15+ years.
Jim
I have a MI3000 and it has been pretty good.
I went to test a job end of last year and got some strange readings. did a Zs test on a ring main and got 0.61 on non RCD but about 2.5 on RCD Zs.
Sent the machine back as I thought there was a fault and it came back fine. Went back to the same site recently and got the same weird result. Harmonics ??
I also find that between the RCD / non RCD Zs test I quite often get up to 0,2 ohms difference, anyone else get similar on any machine. I am told it is because it calculates rather than tests it on RCD Zs
Alphatek MI3000 Easi plus
Electrical Tools and Products
D80,
sparks1234,
