Always-on rear view camera for van | on ElectriciansForums
Discuss Always-on rear view camera for van in the UK Electrical Forum area at ElectriciansForums.net
Bath
Slightly off topic, but is anyone aware of an always-on rear view camera that could be mounted on a retro-fitted rear view mirror? Van has a solid bulkhead and a reversing camera, but keen to have a permanent rear view option to spot those pesky cyclists ;-)
bought one a while ago. the screen clips onto the rear view mirror. that was wired as always on so i had a rear view "mirror" as well as a camera. ideal for solid bulkheads and/or all metal rear doors.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
I've bought a cheap reversing camera from ebay that should override the image on the radio screen using a suitable video adaptor cable.
Currently looking for a suitable place to mount it on the back of the van.
Going to have a momentary push button for viewing while driving, also comes on when using reverse gear.
(using a relay, so my push button doesn't bring on the reverse lights :rolleyes:)
I should have bought a camera with an adjustable mounting bracket. The one I got is built into a wedge shaped piece of plastic and can only be mounted on a horizontal surface, upside down, to give the correct view.
Ideally I would have liked it on the vertical rear door of the van. The angle of view is correct, but the camera would then be upside down.
Looking for a solution to this. The camera is pretty well glued into the wedge so I cant turn it around.
Where did you stick it, Dan? I'm now thinking of either binning this one and getting one on an adjustable bracket, or somehow fix it to the inside of the rear bumper, drilling a hole in the bumper to view out?
I could take a hacksaw to the plastic wedge and remove the camera completely?... then stick it the van door somehow.
Ahhh I have one on a Kia Sedona so just inside the rear window. Keeps it clean and dry. I have a mate with a VW LT35 or whatever that has no windows in the doors that has drilled through the centre of the VW badge on the left door and sneaked it inside. You can't tell it's there looking unless you're right up to it.
You'd need do something clever like that.
Maybe a hole above the key lock so from a few feet away it looks like part of the lock?
Citroen berlingo van. Rear doors are asymmetric, so it can be fitted fully on the main door to be central. No windows, would have to be drilled through the skin.
Has a detachable towbar, so a camera would help on hooking on a trailer, but my idea of fitting it inside the bumper, the towbar would be above the viewpoint and obscure the image.
Door handle height would be ideal, but needs to be at the right angle to see the towbar, and the road when reversing.
I think ill just get an adjustable bracket version, or cut this one up to make it adjustable.
Those wedge ones are supposed to be screwed upwards near where the numberplate lamps are...
[ElectriciansForums.net] Always-on rear view camera for van
Reply to Always-on rear view camera for van in the UK Electrical Forum area at ElectriciansForums.net
