Always trust Yahoo | on ElectriciansForums
Discuss Always trust Yahoo in the UK Electrical Forum area at ElectriciansForums.net
F
fuel
As sad as i am, i was reading where someone had a blown "fuse" on yahoo answers and was looking what to do, and had a bit of a laugh at one of the responses:
" You need to get an qualified electrician out as soon as possible, because he will have to do an insulation resistance test on the light circuit to find the problem. I had a problem like that at a clients house and found that rats chewed through the wiring. It caused a joist to catch fire, but lucky for the client the wires burnt off before causing big damage.
I don't know why rats like to chew electric cables, but they seem to like doing it. If the electrician can find the problem it should not cost to much, to repair, because he can cut the bad or damaged section of the cable out and use junction boxes to join a new part of cable. Just make sure to get a Part P registered electrician to do the work, because it's illegal to do any electrical work without being registered. Get a receipt when he did the work. "
Reply to Always trust Yahoo in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
