am I certified to Sign off fuse board? | on ElectriciansForums
Discuss am I certified to Sign off fuse board? in the UK Electrical Forum area at ElectriciansForums.net
baza890
Trainee
birmingham
Am I certified to sign off/do certs for a fuse board if I've completed my Level 2 and level 3 city and guilds (2365) electrical installation?
(have not done the regs yet or testing & inspection or the NVQ)
In short, I’d say no.
Changing a CU is notifiable work to LABC. The only way you can notify is either through your scheme if you’re a member, or by going through your LABC directly and paying their extortionate fees. (There’s also 3rd party notification, but I’m not opening that can of worms today).
Now I’m assuming that you’re not a scheme member as you’re only part qualified.
So,
In order to go directly through LABC, you’ll need to prove competence to them, and the fact that you don’t hold the 18th, or an I&T qualification yet, makes me think that they won’t accept the certs as I don’t think only holding Lv2&3 will cut the mustard with them. Others may disagree.
After all, how can you prove that the work you’ve completed is to the current standard of BS7671 if you don’t hold the qualification?
Also, do you hold the required insurance to be carrying out work of this nature?
If it your own house then I would just do it
If it is for a paying customer then you will need a Scam to sign it off so probably more agro than its worth for you to bother doing the board
As JBW said.
The only requirement for "signing off" aka issuing an EIC or MEIC is that you are competent.
Are you, and can you demonstrate competency:
1, as the designer - has the installation been designed in all respects in complete compliance with the latest standards (18th+) , also 2, has it been installed in all respects in complete compliance with the latest standards? And finally 3, has it been fully inspected and tested in all respects in complete compliance with the latest standards?
I would suggest this is difficult to prove without knowledge/certification to the latest edition of the regulations, similarly without some testing certification it would also be difficult to demonstrate your competency.
Then, although a different side of things, part p demands proper notice to the local authority, this would normally be expected to be undertaken by you, so either membership of a scam, or direct acceptance from the authority, both of which would require proof of competency via certificates you don't yet have.
Not being funny, but I wouldn't call it a fuse board, as it doesn't contain any fuses.
Would that count for a house you own but rent out ?
Not for a change of an item. But the change still needs certifying. MEIC for that.
So basically anyone could change out the mcbs for rcbos no qualifications or notifications needed, fill out a minor work's job done.
What about just changing the enclosure, from plastic to metal, leaving the rest as is ?
Reply to am I certified to Sign off fuse board? in the UK Electrical Forum area at ElectriciansForums.net
Hi again, "trying to save money" doesn't really come into it. We parted company with the original sparky, as he was so unreliable. Jon
I did my NVQ a couple of years back now and as I was a sole trader as a mate, I was my employer, so they just let me sign both bits
