am i correct in saying that in voltage follower/buffer circuit if there are no resistors present then there is no gain? | on ElectriciansForums
Discuss am i correct in saying that in voltage follower/buffer circuit if there are no resistors present then there is no gain? in the UK Electrical Forum area at ElectriciansForums.net
leicester
[ElectriciansForums.net] am i correct in saying that in voltage follower/buffer circuit if there are no resistors present then there is no gain?
Vin(+) ~= Vin(-) when op-amp is in linear operation
Vin(-) = Vout due to the direct feedback connection
Therefore Vout ~= Vin(+)
Would be equal with infinite gain.
Advantages: High input impedance, high power gain
Disadvantages: With large swings, inputs work under non-ideal conditions far from ground. Stray C can interfere with stability.
Reply to am i correct in saying that in voltage follower/buffer circuit if there are no resistors present then there is no gain? in the UK Electrical Forum area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
Hi Just catching up on some threads. Did you get sorted out for your course? If you are on one now you can apply to join our trainee forum Apply...
