Am I legally allowed to change a light switch on domestic without Part P? | on ElectriciansForums
Discuss Am I legally allowed to change a light switch on domestic without Part P? in the Domestic Electrician Forum area at ElectriciansForums.net
England
My friend rents out a house to someone and the light switch needs replacing like for like. This is obviously a simple job but as it is rented would need to be officially done by someone qualified. I am an industrial electrician and have an NVQ level 3 in electrical maintenance and have been working qualified for 5 years. I am also BS: 2391 (test and inspect) qualified which means I can sign electrical installations off. I am not however part p approved which domestic electricians are required to have I believe. Would I be able to change the light switch over without part P as I have got 2391 and can effectively say it is safe? The fact it is rented is why I am wondering.
Correct
No matter what people say you can not be be part pee qualified or part pee approved
No more than you can say you are gassafe qualified
I still tell customers I'm part P approved and they are almost always clueless what part P is so it doesn't really make any difference if you tell them you are part Z, M or F approved, registered or qualified (it is only 14 years since it was introduced so give it time).
Part pee will mean absolutely nothing to 99% of the adult population...
remind me again how many sparks have been prosecuted for flaunting partpee regulations..?
Most unsafe/dodgy electrical work isn't even probably done by sparks, but builders, mates of a mates, diyers etc.
Regardless of who flauts the part P regs I honestly don't even believe that as many as 1% are prosecuted. I would doubt as many as 0.1% are prosecuted. The exception being that should you dare use the NICEIC logo without paying them for the privilege, then the chance of you being prosecuted increases considerably.
Just to correct you the 2391 Inspection and Testing qualification is not a British Standard but a City & Guilds qualification.
Reply to Am I legally allowed to change a light switch on domestic without Part P? in the Domestic Electrician Forum area at ElectriciansForums.net
Isn't it just a little sad that it should cost sooooooo much to LOG a few jobs to BC.... O where did it all go very wrong ? Signed Man in tights...
It applies to commercial if it shares the same supply as a dwelling.
