Am I liable to pay | Page 4 | on ElectriciansForums
Discuss Am I liable to pay in the UK Electrical Forum area at ElectriciansForums.net
uk
I rent a property in the UK. All of the sockets in my house were tripping, even when all sockets were switched off. An electrician came out, sent by the estate agent who manages the property. They determined it was an appliance of mine that tripped the power. He said something about why the socket was receiving power when the switch was off, but I'm not sure what it was he said as I am no electrician. Something to do with a neutral wire. I have received an invoice, from the estate agents, for me to pay the electrician as the fault was my appliance. I agree this would be my invoice to pay, however, I could have diagnosed the appliance as the fault myself had the landlords socket not been supplying power when switched off? Please could somebody advise me as to where I stand. Of course I am happy to pay if it is my responsibility. Thanks, Jean.
I recently went to a house with and RCD tripping, it turned out to be the toaster. The occupier had dropped something metallic in the toaster, causing a N to E short. After tipping the metal object out, the toaster worked fine and nothing tripped.
funny. i was thinking along similar lines but my thoughts were water splashed or spilt on toaster. now dried out it's OK.
The situation arose because of the Landlords installation being low cost
If the installation did not comprise cheap (and in this case) ineffective single pole sockets,the toaster would have not stopped the supply being reset
The Landlord relied on single pole devices when double pole are prefered and readily available,it not only smells of cheap and nasty but silliness and to a certain degree negligence on their part given the installation is being used for Rental
If they try and charge ask them for compensation for the time you had to endure power off for no good reason
Thats a bit harsh, I bet most of the UK has SP sockets.
Only time I have ever seen a fault caused by a toaster was when someone tried toasting a portion of baguette in one and the width of the bread forced parts of the bread carrier against the elements causing it to trip.
If you are a student, it's common to turn the toaster on its side and slide in a slice with mac and cheese on it...an improvised George Foreman grill...
trust me, bad things happen!
Gotta be sharp with the wicket keepers gloves when it ejects your tasty molten snack is all I will say.
A mate of mine came home to find the toaster smouldering outside the back door. Apparently his housemate had lost his lighter and was trying the old paper on the element trick to get a light! Things escalated rapidly and the flaming toaster was chucked out the door!
@jean1289
The last rogue toaster I looked at had the following "faults"
The crumb tray at the bottom had never been cleared out
A large sultana from a tea cake was wedged inside, shorting out the element to the metal earth of the device.
What I did (you can do this) UNPLUG the thing. Clean it out so there's no debris. That should sort it.
PS I charged my standard minimum of two hours. Easy money!!
@jean1289
did you get a piece of toast as a tip?
Reply to Am I liable to pay in the UK Electrical Forum area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
