sjm
Hi Guys.
Just a quickie I hope.
I need to put 2 x satellite, 1 x tv and 1 x BT (all on 2 gang modular plate) right next to double socket.
I was thinking to use a 2+2 metal backbox, but am now concerned that without it being insulated between band I and band II circuits there could be a problem if a fault occurs. However the backbox will be earthed so I guess that would disconnect supply in the case of a fault.
What do you guys think? I'm sure I'm over thinking the problem and should just get on with it.
Thanks in advance.
Steve.
Thanks in advance.
Steve.
