hanish123
Long story short: I had a electrical problem on a circuit that powers our backyard lights and outlets a few months ago that fried the circuit breaker too. Electrical problem was fixed and I had an electrician swap out the breaker for a new one. At the time, he offered to replace it with an AFCI/GFCI breaker for a bit more money and I thought "what the hell" but I'm beginning to regret it.
We basically get a phantom/nuiscance trip that only occurs after hours of the lights being on in the backyard. The breaker in question actually protects two subcircuits: a first that powers two outdoor outlets that are rarely ever used and a second that powers out entire backyard lighting, with a smart switch that is inaccessible to human fingers. I've tried everything I can think of to eliminate the phantom trips, including recutting the wire ends and reconnecting every single light, adding waterproof connectors, and even rerunning some of the wires in conduit where I thought problems might be originating.
The trips are all AFCI related, as the breaker displays some LED lights indicating that there is an ARC fault instead of a standard overload situation, so I'm thinking I might have been better off with just a standard breaker. I'm thinking of swapping the AFCI breaker with a standard breaker and just replacing the first outlet in the outlet subcircuit with a GFCI outlet to make sure the outdoor outlets themselves are to code, but leaving the light circuit without AFIC/GFCI protection (which I believe is also to code).
Am I stupid to do this though? Is there some reason why I should be paying strong attention to these ARC faults that could cause some sort of big problem down the line, or is this likely what I think it is: a small amount of moisture getting into a light fixture somewhere in the yard that most people wouldn't ever care about or even notice?
