J
JoeDonnelly1
Was asked to run a supply for a 2.8kW fan assisted oven (no hob), I done some cable sizing and voltage drop calculations as well as adding 50% overload and found I could do this using 2.5mm twin and earth cable. I also found I could use a 20A MCB as well but a friend said personally he'd use a 32A to be safe but he didn't give any more info as to why. Would it be best for me to use a 32A MCB and why? Or do I just stick with the 20A MCB? I'm also going to install a double pole switch next to the oven for isolation would it be acceptable to use a 20A DP switch?
