AM2 Fault Finding | on ElectriciansForums
Discuss AM2 Fault Finding in the UK Electrical Forum area at ElectriciansForums.net
SGElectrical
I have my AM2 fault finding resit next week as was wondering if any body had any hints/tips to get me through it.
thanks
what part did you fail on? they did tell you the faults/ give you a list.
which ones were you not sure on (note down all the tests you did in paperwork and right a result e.g. fault on.....)
i did the test on the heating circuit for example and the clue was the client doesnt always get hot water when they need it.
proved everything via testing and put possibly timeclock but needs further investigation.
remember the valves will have a manual release so you can prove your cables from point to point.
write that down as well if everything is correct point-point
what exactly did you do during your fault finding and by that i mean
faults
tests you completed
paperwork - what you wrote down
Reply to AM2 Fault Finding in the UK Electrical Forum area at ElectriciansForums.net
Start with Big Clive on Youtube if you want electronic teardowns.
That is true it is not really a practical class it is expected you have some knowledge of practical testing before the class. I do a lot of...
