Am2 preparing | on ElectriciansForums
Discuss Am2 preparing in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
London
Hi all,
I have my Am2 in 2 weeks time-want to have informations on few things below-
1) Can I do global insulation resistance test
2)for fault finding and rectification, can anyone be able to share format or example how I can write them,also if I need to write what instrument I can use etc
3) for heating system, which cables is used for boiler circuit controller,solar thermal controller and solar controller
Thank you all
  • [ElectriciansForums.net] Am2 preparing
Reply to Am2 preparing in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
You can make these yourself mostly - make your own site diary, instructions and so on.
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Electrical Courses
