Am2 socket circuit help!! | Page 2 | on ElectriciansForums
Discuss Am2 socket circuit help!! in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hi. I've got a resit for the Am2 in a month as I failed the socket circuit. The problem is, I'm not sure how ! I've drawn a quick diagram of the wiring they give you and how I would wire it.
The top drawing is the diagram they give you..
[ElectriciansForums.net] Am2 socket circuit help!!
One of the tested areas, as pointed out earlier in this thread, is following the design criteria. If you don’t follow it you fail.
I watched that @Wilko - it did make me wonder about a couple of threads that have come in regarding heated and melted plug tops and socket outlets - could it be a fake fuse providing a ‘one bar fire’ in the circuit under a loaded condition - next time I tell you, next time!
I shall sacrifice one of every packet of fuses from now on to see if the silica sand pours out - if I’m careful I can put it back in an glue it together again!
There is your 1st mistake it's not a Ring Main, it's a Ring Final circuit
Yes it is old Mate, but trainees need to understand circuit designation. things like calling a RFC a ring main, might be just enough to tip the balance in the examiners thought process, just saying.
You failed as you haven't followed the diagram, they are given to you 1 to see if your competent and 2 to ensure you can follow diagrams, wiring diagrams and schedules etc as they also give you the wiring code ie 6242y so if you don't follow the instructions you fail.
Reply to Am2 socket circuit help!! in the UK Electrical Forum area at ElectriciansForums.net
The video's are an accompaniment to the Book and referenced throughout.
I think I’ll just buy a DOL and play around with it. I don’t remember ever working with one in the real world, I must be missing something obvious...
