AM2S 2WAY & INTERMEDIATE SWITCHING HELP | on ElectriciansForums
Discuss AM2S 2WAY & INTERMEDIATE SWITCHING HELP in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
liverpool
Hi
I am sitting my AM2S next week. I feel fine with all of it except the lighting section. it requires a 2 way and intermediate lighting circuit to be installed. but unsure how to tackle it whether to wire at the switch or to go the light first. not that sure on it.
greatly appreciate if anyone knows or has sat the am2 recently to help thanks:)
Hi
Should say in the spec.
Upvote 0
I’ve installed the bays for the AM2 8 bays and 2 test bay with 46 faults per bay in the test bays controlled via a 2 way switching in a remote room. The wiring to the lighting is feed to the switch first not 3 plate at the light, so the light will have switchwire neutral and Earth only, there’ll be 2 x 2ways and a intermediate switches
Upvote 0
It will tell you exactly how they want it wired. You don't need any knowledge to pass the am2 practical, it's very simple, just follow the instructions they give you carefully. Remember not to worry/panic just treat it like following a wiring diagram in work.
Upvote 0
Wouldn't mind a gander at that wiring diagram 🤣
Upvote 0
Reply to AM2S 2WAY & INTERMEDIATE SWITCHING HELP in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
When I did my AM2, I had it drummed into me that I had to follow Guidance Note 3 carefully. So, did you follow the guidance in GN3 for checking...
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
Electrical Courses
