Amendments | on ElectriciansForums
Discuss Amendments in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
diditrain
north west
What does everyone else do when an amendment is introduced for BS7671, do you just place them loosely into your book or stick them in with glue/other means etc?
The current Amd. 2 is sat on my computer as a .pdf, as it only contains details about electric vehicle points, which I am unlikely to ever need.
Earlier amendments may get a print-out, but usually these are published as a new book if there are enough amendments.
The IET do do a paper copy of amendments, £5 for the current one iirc.
i have an electronic version from IET which i have on my desktop and moblie devices.
YOu can only buy it from IET and you can have it on two compters and one mobile device. You can make electronic notes in them and they are all synchronised. SO what you write in one copy will be seen in al of them.
On my inspection last week i was asked if I had the current amendment and it had downloaded automatically.
Reply to Amendments in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ah my mistake - apologies. I have something more or less like this wylex unit and the flappy plastic cover has got a broken pin so won't stay one...
I think the point made here on knowing the calculations for verification of results etc is a good one. With one question leading onto the next not...
