O
Old Jag Lover
When I worked as a liney for PG&E in 1981,we got a call about a transformer in Baldwin Hills that was belching black smoke,rather than knockout power to about 60 homes I went up in a bucket truck and pulled the dropout fuses off with a death stick,told a young black kid with me.thats a parasite,we'll upsize it from 50 to 100kVA other transformers nearby being 200/200/100 or 200/100 combos,240 volt 4 wire service 13.8kV primary,anbody guess why I called it a parasite transformer also why the dropouts did not blow.
ell my old teacher in the military told me never to have a parochial outlook and American methods at first seemed strange but I will explain,a parasite or stinger transformer wasused in the old days to allow a three phse load,usuall,HVAC to be added to a npormall aingle phase 240volt center tapped neutral transformer the stinger is always the small one,usually in an open delta setup. now of corse most 3 phase setups are 120-208 there.there is a trap with a closed delta too,the top is called the high leg and produces 208 to the neutral saw a bank of computers stuffedup this way when a sparky wondered why in the pael every third slot was vacant and slotted in a breaker,rather than say double tapping two lightly loaded ccts and placing his new cct there.
Fair play to you Tony,but now,everyone on the bus has seen who the eccentric fella has chosen to sit down next to,and will relax and watch the fun....
American electricity
Old Jag Lover,
Geordie Spark,
