If I were to extend circuit cables using a DIN rail enclosure and DIN mounted terminal blocks would the enclosure need to be made of a non combustible material?
Discuss ammendment 3 apply to din rail enclosures in the UK Electrical Forum area at ElectriciansForums.net
So an adaptable box with a DIN rail and DIN rail mounted terminal blocks would not be classed as switch gear.
I was told by a Wylex rep the other that only an enclosure with fuses/mcbs is require to be non combustible. So say an upfront enclosure with main switch or RCD doesn't need to be non combustible
I agree, but, as we should have all read, this ammendment came about due to London fire brigade being called out to fires started within consumer units because of loose connections on account of shoddy workmanship. As I will be using push-in terminal connectors I won't really have to be to concerned with screw terminations, but perhaps if someone where to use screw terminations then the ammendment should apply, should it not.
Madness really.
Like a Wylex rep is a Technical Engineer ..NOT !!!! the minute I start taking any notice on the claims that rep's make is the minute I shoot myself.
That and the fact that their friggin MCBs were all catching fire a few years ago!Like a Wylex rep is a Technical Engineer ..NOT !!!! the minute I start taking any notice on the claims that rep's make is the minute I shoot myself.
Reply to ammendment 3 apply to din rail enclosures in the UK Electrical Forum area at ElectriciansForums.net
