Amptec Electric Flow Boiler Relay Control Alternatives | Page 2 | on ElectriciansForums
Discuss Amptec Electric Flow Boiler Relay Control Alternatives in the UK Electrical Forum area at ElectriciansForums.net
Mishto
SO40
Hi All,
First post for me . Am about to replace/install two Amptec C900 electric boilers (from old Amptec to newer Heatrae Sadia versions).
Under the current regs and specs for these boilers it is recommended that two relay units from Heatrae Sadia (RF 1 & RF 2) are used. One to insure pump operation if any one boiler is running and the other due to an electric shower being installed at the same property. Does anyone have any cheaper solutions, installing the proprietary relays from Heatrae which are going to set me back over ÂŁ250!
I know I need potentially 3 relays (240v, 10A, 2 x Normally Open Contact and 1 x 240v Normally Closed contact - for electric shower) just want to make sure I get good quality stuff.
This is for my girlfriends property so could possibly earn a few extra brownie points if I can get this up and running between Xmas and New Year!
Any pointers, advice, recommendations or abuse welcomed in equal measures.
Many thanks for any help/assistance in advance.
Ps am aware of similar post from 6 years ago, just wanted to keep it current and hopefully more conclusive.
Reply to Amptec Electric Flow Boiler Relay Control Alternatives in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
I
Baxi system boiler and Opentherm Hello Does anyone know if its possible to connect an Opentherm thermostat such as a Nest to a Baxi 800 System...
Ian777
I
