W
WELSHTESTER
I've loaded the new 2013 Amtech software this week and have found that it's quite poor
on the new software they have added an extra program to the desktop, a new EICR certificate, unfortunatley though several of the time saving short cuts and extras are missing, i.e, there is no "fill all blanks with n/a", it does not automatically insert the test instruments serial numbers, it also does not fill in the insulation resistance boxes automatically either so due to this it takes much longer to fill the form in
I phoned the helpline only to be told that all theese shortcuts and features will be added in the update later in the year
I also tried to open a new periodic certificate with an existing certificate/installation that I have done before in the database but found that most of the information was missing, i.e, the circuit designation info was there but the type of cable, reference method, size of cable, size of mcb were all missing and had to be entered manually again which caused me to take 2 to 3 times longer than predicted to fill in and complete the form
Has anybody else had the same trouble? any tips? or can anyone recommend an alternative to amtech?
thanks
thanks
